Update failed to install
  • Update failed to install
    Tried the new beta 3.0.0.10 PI and I'm not seeing the new humidity. I am seeing this error in the logs though.
    12/3/2014 6:05:17 AM ~!~Nest~!~ERROR Method not found: 'Int32 NestSharp.NestThermostat.get_humidity()'.
    you probably failed to install the new NestSharp.dll
    you need to follow the installation instructions from the first post of this thread so that all the dll in bin/Nest are updated.
      I reinstalled it and I'm now not seeing the error in the log but still not seeing the humidity device. What am I missing?
        can you post the logs of the installation and when you start the plugin
          Where would I find those logs?
            from the HS web interface: VIEW > Log
              Looks like its still generating that same here:
              Dec-03 5:59:46 PM Nest ERROR Method not found: 'Int32 NestSharp.NestThermostat.get_humidity()'.
              Should I uninstall the PI, then reinstall it?
                stop the plugin, delete everything in bin/Nest, then install again, then please post the installation logs and start of the plugin, i.e. something looking like this:
                Dec-03 7:48:21 PM Nest INFO Nest version 3.0.0.10
                Dec-03 7:48:20 PM Info Plugin Nest has connected. IP:127.0.0.1:8430
                Dec-03 7:48:12 PM Updater Install/Update of package Nest was successful.
                Dec-03 7:48:12 PM Updater Warning File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Config\\Nest.ini
                Dec-03 7:48:12 PM Updater Extraction Complete.
                Dec-03 7:48:12 PM Updater Extracting files from zip file: images.zip
                Dec-03 7:48:12 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Nest\NestSharp.dll
                Dec-03 7:48:12 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Nest\FirebaseSharp.dll
                Dec-03 7:48:12 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Nest\System.Threading.Tasks.dll
                Dec-03 7:48:12 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Nest\System.Runtime.dll
                Dec-03 7:48:12 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Nest\System.Net.Http.dll
                Dec-03 7:48:12 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Nest\Microsoft.Threading.Tasks.Extensions.dll
                Dec-03 7:48:12 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Nest\Microsoft.Threading.Tasks.Extensions.Desktop.dl l
                Dec-03 7:48:12 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Nest\Microsoft.Threading.Tasks.dll
                Dec-03 7:48:12 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Nest\Newtonsoft.Json.dll
                Dec-03 7:48:12 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_Nest.exe.config
                Dec-03 7:48:12 PM Updater Installing package Nest
                Dec-03 7:48:12 PM Updater Using local file: Nest_3-0-0-10.zip
                Dec-03 7:48:12 PM Updater Downloading update: Nest
                Dec-03 7:48:12 PM Updater Starting download of updates
                  Here is the results of the install.
                  Dec-03 7:02:16 PM Updater Install/Update of package Nest failed.
                  Dec-03 7:02:16 PM Updater Error Installation of package Nest failed. Try disabling the plugin first, then re-try the update.
                  Dec-03 7:02:16 PM Updater Error Copying source to C:\Program Files (x86)\HomeSeer HS3\bin\Nest\Newtonsoft.Json.dll, detailed error: Access to the path 'C:\Program Files (x86)\HomeSeer HS3\bin\Nest\Newtonsoft.Json.dll' is denied.
                  Dec-03 7:02:16 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Nest\Newtonsoft.Json.dll
                  Dec-03 7:02:16 PM Updater Making dir: C:\Program Files (x86)\HomeSeer HS3\bin\Nest\
                  Dec-03 7:02:16 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_Nest.exe.config
                  Dec-03 7:02:16 PM Updater Installing package Nest
                  Dec-03 7:02:16 PM Updater Using local file: Nest_3-0-0-10.zip
                  Dec-03 7:02:16 PM Updater Downloading update: Nest
                  Dec-03 7:02:16 PM Updater Starting download of updates
                  I changed the security on the Nest folder and reinstalled it again and now its working perfectly. Thanks!
