2 Nest thermostats in HStouch show different
if both of your thermostats can heat only, they should appear the same in HSTouch, and only the Heat buttons should be operational.
what version of the plugin are you running?
try to delete all the devices for the thermostat which isn't showing properly in HSTouch, then restart the Nest plugin, then restart your HStouch client to see if that fixed your problem.
if you still see a problem, set the log level to debug then post one of the log line that looks like this:
Code:Nest DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"kLuctCX8ckMlIi.......
