Forgive me as I am not a programmer. But I am trying to change the target temperature by script. I used hs.setdevicevaluebyref and I am able to change the value of the device in homeseer but the actual nest device doesn't change. The reason I am using scripting to do it is so I can use voice recognition to change the thermostat. I then have a script parse out the temperature in the hs.lastvoicecommand and use hs.setdevicevaluebyref to set the temperature. Anything I can do to change it? thanks.
Scripting
you can't use SetDeviceValueByRef to control a device from a script, you have to use CAPI: http://www.homeseer.com/support/home...ontrol_api.htm
there is a lot of CAPI examples in the forum.
Let me know if you can't figure it out, I'll try to come up with an example for the Nest target temperature
Originally posted by spud View Postyou can't use SetDeviceValueByRef to control a device from a script, you have to use CAPI: http://www.homeseer.com/support/home...ontrol_api.htm
I was afraid of that. I've been trying to avoid looking into the dreaded CAPI but I guess i'll have to. Thanks.
