How can i change the RC2000 Temperature sensor config via the plugin
    i have an external temp sensor connected to the tstat. I want be able to enable/disable the built in temp sensor as will as the external one; sort of switch back and forth
    Mark
    HS3 Pro 3.0.0.534
    You must do it with the thermostat configuration at the thermostat. The plugin doesn't provide this capability.
      thanks Kirby. so is the issue that there are no registers that the plugin can update? or is it that the plugin can't update those registers for some technical reason?
      Mark
      HS3 Pro 3.0.0.534
