Using the Omnistat3 plugin with the new HS mobile app
    Kirby
    Have you tried the new mobile app with your plugin? One issue i see is that the temperature adjustments (up and down) don't work. The app just pops an Error msg (with no text)
    Mark
    HS3 Pro 3.0.0.534
    No, I haven't tried it. I'll try and take a look in the next couple of weeks. Pretty busy right now.
      No rush. thanks Kirby
      Mark
      HS3 Pro 3.0.0.534
        I just tried the mobile app and everything appears to work fine. I adjusted the heat and cool setpoints, the mode, and the fan. I didn't get any errors.
        I am using the IOS version. Which version are you using?
          Kirby,
          I'm using the iOS version as well. for some reason i cant get the set points to adjust. when i click the temp up or down, I get an error popup. see attachment
          what version of HS3 are you running? I'm at 3.0.0.500
          Mark
          HS3 Pro 3.0.0.534
            What version of HomeSeer. I'm running HS3 Standard Edition 3.0.0.500 (Linux).
              Sorry, I didn't read your post close enough. How about your iphone? I have an iphone 8 running IOS version 12.2
                On Android (Android v9, HS Mobile v1.0.6-93, HS3 3.0.0.531 Win10), I get a popup box just like mnsandler but with additional text: "Error, Cannot control thermostat. There is a problem with the set-point control configuration."
                  HMM.... Attached is a zipped MP4 file of my iphone screen showing me exercising the buttons with no errors (pardon my fat fingers hitting some extra stuff).
                  Maybe HomeSeer Tech has some insight into this.
