Contacting HomeSeer This Week
See more
See less
strange behavior with night occupancy mode
  • #16
    every time i go to the program setup, it changes the heat setpoint to 66 regardless of what is on the program screen (like on #8 above)
    That is very strange. Do you have more than one thermostat? Are you using the plugin's SetRegister method in any events?
    • #17
      i have two omnistat2 units. they are assigned different addresses (1 & 2). i'm not using the SetRegister method
      i think i may have to reset the unit and then reprogram it.
      Mark
      HS3 Pro 3.0.0.534
      • #18
        I'm assuming then that your other stat is not exhibiting these issues.
        Let us know how the reset works for you.
        • #19
          i didn't reset the unit, but i did change the programming directly on stat again and the issue seems to be resolved. changing to night mode seems to set the temp correctly
          Mark
          HS3 Pro 3.0.0.534
          • #20
            Glad to hear it.
            • #21
              I wanted to followup on this topic...
              it seems like the Omnistat2 Occupancy mode uses the temps set in the programming, and just allows the plugin to change the mode but not the temps.
              so when i change a Day Setpoint in the plugin, it does not change the programming on the omnistat2 , correct?
              should i change the mode on the omnistat2 to None so that the plugin will set the temps accordingly
              Mark
              HS3 Pro 3.0.0.534
              • #22
                Mark,
                On the Omnistat2, If you change any of the occupancy temp device values (i.e. Day Heat Setpoint), the plugin will change the corresponding value on the thermostat programming. I confirmed this behavior on my RC-2000.
                If this is not working for you, then let me know what method you are using to change the device value.
                • #23
                  Kirby,
                  well now its working as you described. I stood in from of each stat and changed a few different set points via hstouch and the changes were reflected on the stat Program screen.
                  are there any plugin triggers that i can use when a transmission error occurs between the plugin and the stat? this might be the only way i can determine when i'm having this issue.
                  Mark
                  HS3 Pro 3.0.0.534
                  • #24
                    There aren't any triggers. You could turn on Comm error logging. Maybe one of the log plugins could screen for the comm errors and notify you.
