every time i go to the program setup, it changes the heat setpoint to 66 regardless of what is on the program screen (like on #8 above)
strange behavior with night occupancy mode
i have two omnistat2 units. they are assigned different addresses (1 & 2). i'm not using the SetRegister method
i think i may have to reset the unit and then reprogram it.Mark
HS3 Pro 3.0.0.534
Hardware: Insteon Serial PLM | AD2USB for Vista Alarm | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire3 | RFXCOM | NetCAM | MyQ | BLRadar | BLDenon | Jon00 Charting
Platform: HP h8-1360t, Windows Server 2012 R2, i7-3.4GHz, 16GB memory
i didn't reset the unit, but i did change the programming directly on stat again and the issue seems to be resolved. changing to night mode seems to set the temp correctlyMark
HS3 Pro 3.0.0.534
I wanted to followup on this topic...
it seems like the Omnistat2 Occupancy mode uses the temps set in the programming, and just allows the plugin to change the mode but not the temps.
so when i change a Day Setpoint in the plugin, it does not change the programming on the omnistat2 , correct?
should i change the mode on the omnistat2 to None so that the plugin will set the temps accordinglyMark
HS3 Pro 3.0.0.534
Mark,
On the Omnistat2, If you change any of the occupancy temp device values (i.e. Day Heat Setpoint), the plugin will change the corresponding value on the thermostat programming. I confirmed this behavior on my RC-2000.
If this is not working for you, then let me know what method you are using to change the device value.
Kirby,
well now its working as you described. I stood in from of each stat and changed a few different set points via hstouch and the changes were reflected on the stat Program screen.
are there any plugin triggers that i can use when a transmission error occurs between the plugin and the stat? this might be the only way i can determine when i'm having this issue.Mark
HS3 Pro 3.0.0.534
