Switched to HS3 over the Xmas break and initially used the HAI Omnistat plugin to control my four thermostats (2 RC80's and 2 RC100's). They were working fine with HS2 for several years and continued to work fine with HS3 and the Omnistat plugin. Having some issues dealing with the fractional temps, really want to setpoint to be 72, (not 71.6). Stumbled upon the Omnistat 3 plugin by Kirby and gave it a try. Like the looks and operation of this plugin much better! (thanks so much Kirby!!) But I've ran into one very major problem. I've had no problem enrolling thermostat addresses 1 thru 3 which happens to be the two RC80's and one of the RC100's. When I go to add the last at address 4 the "Enroll Thermostat" button is dimmed no matter what I do and I can't add my last thermostat (which is an RC100). If I disable the Omnistat 3 plugin and re-enable the HAI Omnistat plugin the last thermostat works fine (I can read values and set parameters). I disable the HAI Omnistat plugin and re-enable the Omnistat 3 plugin and still no joy.
Any ideas or suggestions would be greatly appreciated! I'd really like to switch to this plugin but before I mod all my HSTouch clients for it I need to have that last thermostat working!
Thanks!
Georgia Dutchman
Thanks!
Georgia Dutchman
