New Error in Log
  • New Error in Log
    Exception in UpdateThermostats: System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_RadioThermostat.Thermostat.Update() at HSPI_RadioThermostat.Thermostat..ctor(String IP, HttpClient WebClient) at HSPI_RadioThermostat.Util.UpdateThermostats()
    Any ideas ?
    Looks like it cant find the IP of your thermostat. You restart the plugin yet? If not give it a restart and let me know if it helps.
      Yes shut down and restarted, the stat is at 192.168.1.95 not sure why its not finding it...I tried putting it in the plugin setup screen as well still not finding the stat.
        I'm out of town right now, but will be back tomorrow and I can help look deeper then.
          Ok
            Still looking for help with this error...
              Yep, I'm looking into it.
              From the error you gave me, it indicates a new thermostat object is being created with no IP address. There are 7 locations that call that, I'm tracking back each one of them to see why it would not pass the correct IP to the constructor of the thermostat object.
                From what I can tell, it looks like the homeseer object may have lost it's extra plugin data that allows the plugin to find the correct devices.
                Have you tried deleting the existing thermostat devices in homseer yet and letting the plugin do a brand new discovery?
                Also, have you tried a reboot?
