RCS Serial ERROR
    RCS Serial ERROR
    I have been running the RCS plugin with HS3 for at least a year and just recently starting seeing this error multiple times a day "Error in ProcessCMD, Selecting Properties, Conversion from string "I" to type 'Integer' is not valid". Is this a known issue and is there a fix.
    I would reboot everything (HS3 Machine reboot and power cycle RCS devices). Krumpy has updated this software and eliminated the set point bugs. I am assuming if you have used it for more than a year you have already figured out a work around. I don't believe his improvements would solve the problem you are seeing, but I am far from an expert.
