In my HS3 install with RSC Serial plugin, I have 6 thermostats enabled and they are working. Interestingly, each function of each thermostat is configured as HS3 device. So, for the 6 thermostats, I have 48 HS3 devices (8 per thermostat). The problem I am hoping to solve is HSTouch support of these 6 thermostats. These 6 thermostats do not appear in HSTouch climate menu. Instead, I see the 48 devices in Lighting and Devices menu. Do I need to write some scripts or create customer HSTouch menu in roder to see these thermostats under climate? Help please.
F
F
