Installed the latest, receiving the following errors in the log, even though it appears that everything is working fine.
12/28/2006 8:34:48 AM RCS Serial Thermostats Error in ProcessCMD, Selecting Properties, Index was out of range. Must be non-negative and less than the size of the collection.Parameter name: index
12/28/2006 8:34:48 AM RCS Serial Thermostats Unable to Interpret Command: SC}½›¿þA
12/28/2006 8:35:48 AM RCS Serial Thermostats Error in ProcessCMD, Selecting Properties, Index was out of range. Must be non-negative and less than the size of the collection.Parameter name: index
12/28/2006 8:35:48 AM RCS Serial Thermostats Unable to Interpret Command: S_qÿ˵ÿA
12/28/2006 8:36:48 AM RCS Serial Thermostats Error in ProcessCMD, Selecting Properties, Index was out of range. Must be non-negative and less than the size of the collection.Parameter name: index
12/28/2006 8:36:49 AM RCS Serial Thermostats Error in ProcessCMD, Selecting Properties, Index was out of range. Must be non-negative and less than the size of the collection.Parameter name: index
12/28/2006 8:36:49 AM RCS Serial Thermostats Unable to Interpret Command: SCøÚû_A
