I have installed the latest version (dll) after getting rid of the ocx file. I have a 4 zone system with t-stats connected to a zcv4 which is connected to a 8ah232 and finally into the computer. The three t-stats are set to address 1,2, and 3 by the zcv4 board.
When set up as zone controllers:
The first stat shows fine in your software but the other 2 don't show any data/temp on your page but do in the HS2 status window.
When set up as stand alone:
When set up as stand alone with address' 1,2,3 all three t-stats show in your software and also in the HS2 status page. I set the t-stats up with the address 1,2,3 corrisponding with the zones 1,2,3.
With both setups I get the following:
I a getting the following:
Entering ProcessCMD, CMD=A=0 O=3 H1A=1 H2A=0 H3A=0 C1A=0 C2A=0 FA=1 VA=0 D1=0 D2=1 D3=1 D4=0 SM=H SF=1 SCP=20
"In processCDM, property= D1"
"unable to interpret command D1"
followed by "In processCDM, property= D2" "unable to interpret command D2", "In processCDM, property= D3""unable to interpret command D3" and finally "In processCDM, property= D4" "unable to interpret command D4" and than it loops back through them.
What might I have done wrong in the setup and what is the D1 - D4 anyway? What else do you need to know to correct the problem I am having
Bill
Bill
