FYI, and I'm not sure if this is only with the latest version or not... Without this plug in running, homeseer.exe averages about 2% CPU usage. When this plug in is enabled, HS goes up to an average of 24% and pretty much stays there. To duplicate this, disable the plug in, take a look at your average, enable the plug in and see what the average is for HS. Obviously these numbers will vary depending on your setup, but there is a definate difference here.
CPU Usage
CPU Usage
HS: 2.5.0.60
Environment: Virtual XP as guest in VMWare Server running under Win 7
Plug-ins: MLHSPlugin|RCS Serial Thermostat|UltraLog|UltraMon|
Misc: 303 Devices, 313 Events, 68+ Scripts
HSeer: 3.0.0.54
Plug-ins: BLGData|BLRF|BLRadar|BLRandom|BLSpeech
UltraM1G3|UltraECM3|UltraMon3|UPBSpud|Z-Wave
Misc: 148 Devices, 116 Events, 9+ Scripts (so far, still converting)Tags: None
Will do, thanks for the quick reply! It wasn't a show stopper by any means as the plug in has been 100% reliable with my zone controller. Thank you for for all the work you've put into this!!HS: 2.5.0.60
HSeer: 3.0.0.54
