Hold status after reboot is incorrect.
I am also seeing this problem with the latest plug-in (version 2.3.2770.14681). I'm using two TR40's and the problem happens with each.
The TR40 labels this as "hold" or "run". The plug-in calls this "hold" or "normal". It would be nice to correct the plug-in wording so it matches the actual thermostat.
It appears the plug-in can control the hold/run setting without any problem. It simply doesn't read the status correctly. If the hold/run setting is changed on the thermostat, the new value should (eventually) be reflected in the plug-in.
Thanks Mountainman. To the HS folks, perhaps this clarification will help chase down the bugs.
1. The reporting of Hold/Normal is inaccurate and inconsistent. I have 5 TR40s and when I set all of them to "hold", some report that way and some still say "normal". The reporting of temperature setpoints and actual temperature appears fine.
2. The reporting problem appears on the HS Status page, as well as the RCS Serial tab. Using the buttons on the RCS serial tab, one can set "hold" but it does not report as "hold" even after the button click.
3. A separate issue (not at all critical for operation): The HS status page always reports the Last Change as "Never Set". It would be nice to see it report the last time that HS changed the thermostat settings.
Thanks. This is a great plug-in.
