1) Does the TR40 come with a display and controller?
2) If so, how can one purchase a second display without needing a second controller?
3) How is it wired with multiple displays using a single controller? Do both displays run to the same connections (parallel) on the single controller?
4) Are both displays synchronized or do they individually control the controller and thus the HVAC system?
I have a 2-story house with single zone heat. The top floor always gets hotter than the bottom floor. I want to be able to have the heat set to 68 downstairs when I am awake and then change to have the heat set to 68 UPSTAIRS when I go to bed (I can send an X10 or HTML command w/ Homeseer to inform the logic of when I go to bed).
5) Can this be done with one display downstairs and a remote temperature sensor upstairs? I know it can "average" the temps, but that's not what I want (see my description above again).
6) Can this be done with two displays; one downstairs and one upstairs?
I've looked into all of the manuals and searched the boards but could not find much on this topic.
Thanks!
Thanks!
