Buying a TR40
  • gearyt
    I agree. many things need to be done with both the RCS and HS ends
    RCS is working some of the issues, you may want to contact them again
    It is the most reliable interface I have
  • zimmer62
    Originally posted by gearyt View Post
    I use the Z wave adapter with the RS-485 heads
    I was too, for a while. There were a few things I couldn't do that I wanted to like set the outside temperature on the wall unit via homeseer.
    I contacted RCS and they said talk to ZenSys, who said talk to RCS, who said talk to ZenSys, who said it's not supported. It may have changed since then, and if so I'd switch back to zwave...
    If not, I'd be happy to sell that zwave->rs485 adapter to someone who doesn't care about that feature.
    ZWBT-485 for sale? Anyone know if you can set outside temperature via zwave->rs-485?
  • gearyt
  • jstaab
    I seriously doubt that they are upgradeable. I had an RCS zone controller that had a firmware defect. The only way to fix it was to swap out the controller with a replacement.
    Originally posted by mhog View Post
    Are the older hardware versions completely upgradable with firmware to equal the newer shipped models?
  • NJ Bill T
    Guest replied
    Originally posted by macromark View Post
    All of the RCS serial thermostats are designed with an RS485 interface. They don't make RS232 native models. However, they do make an RS485-RS232 hub that they recommend for the conversion:
    http://store.homeseer.com/store/8AH4...S-P626C38.aspx
    I bought 2 TR40s on BestBuy auction site and have to admit, I didn't give a lot of thought to the RS-485 part. Has anyone tried a USB to RS-485 converter like these?
    http://www.usconverters.com/index.ph...FdA65QodnV5BRQ
    Or this
    http://cgi.ebay.com/New-USB-2-0-To-R...#ht_1819wt_965
  • mhog
  • macromark
    Originally posted by Bill Brower View Post
    I guess you did say they don't make instead of they have never made...
    correct. The unit you have dates back to 2003. The only units made now are RS485 native.
  • Bill Brower
    Unless I am missing something -- Ta-da!
    http://www.resconsys.com/docs/thermo...1-01070-03.pdf
    Installation and Operation Manual
    PN: 141-01070
    Revision 03
    Date: 5/22/03
    Applies to these TR40 Revisions or later
    Model Part Number Firmware Version
    TR40-232 001-01070-07
    TR40-485 001-01080-07
    TS40 WDU 001-01060-07 3.05.5
    HFR-232 CU 001-00810-07 3.04.3
    HFR-485 CU 001-00820-07 3.04.3
    Mine has the little sticker on the control box like the one in your photo but it says TR40 RS232 Model and I'm pretty sure I wired my serial cable right the board.
    But I will concede I can't find them for sale anywhere.
  • zimmer62
    I have the z-wave TZ40 which is zwave (using an adapter that connects to the RS485 port on the control unit), but I'm using it with the RS485 interface instead. There were a few features that I wanted to use such as messages and setting the outside temperature that didn't work with the z-wave interface.
    If anyone is ever looking to convert their RS485 thermostat to zwave, PM me and maybe you could get some use out of this little converter box.
    Great thermostat!!
  • macromark
  • Bill Brower
    They are fine units.
    Watch out, there are RS-232 models and RS-485 models.
    RS-232 will attach to the COM port of your computer.
    RS-485 will attach to the COM port but only after installing an RS-485 to RS-232 adapter. They are inexpensive on eBay and such.
  • macromark
    Ta-Da!
    http://store.homeseer.com/store/TR40...S-P325C38.aspx
  • kaldoon
    Yes - the TR40 comes with both the Wall Display Unit (WDU) and the Thermostat Control Unit (TCU) included - haven't tried to hook it up directly to a computer running HS
  • yeahprolly
    started a topic Buying a TR40
    Buying a TR40
    Does anyone know if the TR40 comes with both the Wall Display Unit (WDU) and the Thermostat Control Unit (TCU) included?
    Also, can the TCU be hooked up directly a serial port on the computer running homeseer?
    Thanks all!
