My TR60 thermostat send the info to the HS system. However when I put a change in on the computer the thermostat neer gets the change. I appears as if the wiring is correct since I do get the from the stat. Did I miss anything on the set up? Any suggestions!
RCS Communication Problem
updating thermostat
I am using the thermostat status button, it then pulls up teh thermostat with all the information as far as current temp and set point. I than change the set point and hit teh button next to the new set point. A blue bar appear at teh bottom of the screen as if it is transfering the data. However nothing changes on the thermostat.
Originally posted by Sailor View PostI am using the thermostat status button, it then pulls up teh thermostat with all the information as far as current temp and set point. I than change the set point and hit teh button next to the new set point. A blue bar appear at teh bottom of the screen as if it is transfering the data. However nothing changes on the thermostat.-Rupp
Originally posted by Rupp View PostWhat version of HomeSeer are you running? Do you have the latest RCS plugin loaded from the HS updater? Are there any errors in the HS log file when the commands are sent?
