Am thinking of upgrading from the old RCS Serial plug-in. Should I? What are the things I need to watch out for?
I do realize I'll have some work to do like update my scripts (to calculate runtimes, etc.) and redo my events so am asking more about the stability of this plug-in (It gets cold where I live and HVAC is a critical system) and about any key features in the old one that aren't in the new one.
Am running HS 2.4.0.11 and have only one TR40 stat. Problem wise I have been getting an increasing amount of intermittent reports in my logs (from an event I created) of the stat having been set to 0 degrees for a few minutes - not something anyone or any event/script did, and it so far has always come back to report the actual setpoint after a few minutes (I haven't noticed if the stat actually goes to 0 or if it's just a comm burp along the way). Of course, this could be hardware related - and maybe the new plug-in will help me figure that out?. There are also bugs around reporting/knowing the hold mode in the current plugin and, of course, the messages at startup that a "property has been deprecated and should not be used" - suggesting I'm living on borrowed time?
I browsed the forum a bit and it looks like most of the problems and bugs have been or are being worked out. Is that the case?
Any advice or comments would be appreciated.
