I have a large system with 5 individual thermostats, and 3 4 zone controllers. One of the singe units is wired directly to the RCS hub. The others all go through hubs before joining the final RCS hub at the homeseer unit.
If I only hook up the one single unit that does not go through a hub that thermostat works fine.
If I add any of the other thermostats which first go through hubs nothing works. Is there an issue with hooking an RCS hub to the RCS hub at the homeseet?
