Is there any way via the plug-in to set the outdoor temp? There is a standard RCS serial command to do this but I don't see a way to send this command.
MESSAGE FORMAT
Command messages use the following format:
Address code, Originator code, Zone code (obsolete), Command, Command, Command,...CR (commas optional)
SEND OUTSIDE TEMPERATURE COMMAND. Format: OT=xxx, where “xxx” = temperature in degrees.
Sends the outside temperature data from the network to the control unit. Used when outside temperature
information is to be used and displayed on the WDU. Note that if the control unit has built-in outside sensor
capability and the sensor installed, this command will have no effect.
Range: -64 to 190 degrees
MESSAGE FORMAT
