Hi All,
I have released a Plugin to control and get status of the myAir Air Conditioning system.
This plugin will interface with, report and control your myAir (myPlace) Aircon controller. You can run any combination of events within your system based on different myAir conditions. The inside temperature is too hot, no problem, have HS3 turn myAir to cooling and get the house back to a comfortable temperature. MyAir supports up to 10 zones and individual room airflow control.
Userguide is here: rnbPlace - Userguide
Support/Issues/Bugs
I utilise a simple issue tracking system for issues/bugs/enhancements with the main reason to ensure I don not miss any issues raised and I have a running clock on each issue so it gets dealt with in a timely way. Issues/bugs can be raised at the site below to ensure timely review and resolution.
- Allows HS3 to trigger events on myAir alerts
- Allows HS3 to control your myAir target temperatures and settings
- Allows HS3 to control your Aircon zones target percentage/temperatures
- HomeSeer Mobile Ready
- HomeSeer HS3 or HS3PRO (HS4 native plugin development is underway)
- myAir5 (myPlace)
Support/Issues/Bugs
- 3.0.0.2 - Initial Release
