Initial Release.
    Initial Release.
    Hi All,
    I have released a Plugin to control and get status of Samsung Wifi Smart Devices. This plugin is mainly aimed at Samsung Wifi Airconditioners, but will also allow status updates from Samsung Wifi Washing Machines.
    It can communicate with Samsung Wifi Ovens, However I do not have one of these, So am Unable to test, If you have one please contact me and I can work with you to enable it.
    At this stage it will not control the Washing Machine, This is Possible, but i have chosen not to implement as I personally have no need, More use it to get an update of when the washing is done and how long it has left.
    The Air Conditioners have Full Control and are Implemented with the Thermostat API so can be controlled by Google Home through Homeseer.
    Please let me know if you have any troubles with the plugin and I will be happy to help.
    Mat
    Hi Mat
    I have a Samsung aircon/ heatpump and would like to test
    I don’t see your plug in in the list- is it released yet?
    thanks
      Hi BrianB,
      Thanks for your message, The Plugin is located at :
      https://shop.homeseer.com/products/m...lug-in-for-hs3
      And is available in the Updater in the same name.
      Please let me know if you have any troubles.
      Mat
        does this interface with their family hub refrigerator?
        HS4 Pro on Shuttle NC10U, Win10; Z-NET
        Number of Devices: 1005
        Number of Events: 293
        Plug-Ins: BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, Marquis monoprice Amp, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, rnbWeather, Worx Landroid, Z-Wave
        External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
          Hi Mat
          Cannot find it in the Update list. Ser attached
          regards Brian
            Hi Jmaddox,
            I doubt it, The Fridge was released a far while after the Air Con units and i dont believe its the same protocol.
            I Personally don't have a Family Hub fridge, But if I get one I will look into making a plugin for it.
            Mat
              Hi BrianB,
              Is your Homeseer Linux based? As the plugin is only tested on Windows... I don't see a reason it wouldn't work with Linux, I will try and test it over the weekend and if all goes well ill get it listed for Linux support.
              Mat
                Hi Mat
                My HS is
                HS3 ZEE S2 Edition 3.0.0.534 (Linux)
                  BrianB,
                  Thought so, Not supported on Linux just yet.... Will have a look at it over the weekend, I don't think any of the code will have a problem running on Linux, So if all goes well ill add linux support.
                  Mat
                    Hi Mat
                    sounds great
                    do you have some kind of description of the functionality in the plugin?
                    regards Brian
                      Hi BrianB,
                      I just realized the User Guide is not on the listing, Ill fix that up.
                      In the Interim Please find attached the User Manual.
                      Mat
                      Samsung Smart Device Plugin for Homeseer 3.pdf
                        Thanks Mat,
                        I have two indoor units and one outdoor.
                        They are connected via the Samsung WiFi kit and in SmartThings app.
                        do you think that will work too?
                        regards Brian
                          Hi BrianB,
                          As I mentioned I am working through getting the Linux supported, Encountered a few issues, So hopefully ill get them resolved shortly.
                          As for support, I am fairly certain Samsung only has 1 local Air Con API, So i believe they should work, There are 2 API's in the Units, A Local control and a Cloud Version, The Cloud is typically whats used for Smart Things Integration, The Local API is what is used in the Plugin.
                          Best was is to install the plugin when I fix the linux issues and give it a go.
                          If you units work with the stand alone Samsung Air Con App then the chances are your good to go.
                          Mat
                            Any chance you'll add support for Samsung robot vacs (wifi)?
                            My home is smarter than your honor roll student.
                              Hi Mat_Budden , this looks really good, just want to confirm:
                              Do you know if it will work with the Samsung "Duct S" range of ducted, multizone split-system air conditioners? It looks like it uses the Samsung "WiFi Kit".
                              https://www.samsung.com/au/air-condi...AC140HBHFKHSA/
                              How will the plugin react to a multi-zone system? Will each zone be created as individual sub-devices? Will there be separate temperature set-point and air volume controls per room?
                              Thanks.
