Hi,
I have today changed some of my setpoints to adjust the season changes.
When I try to change the frost setpoint, it just goes blank.
Pressing increase, decrease or submit does not work.
I first noticed it when I tried to use the Increase and Decrease buttons. The setpoint did not change. So I then entered the desired setpoint manually, and pressed Submit.
Then the setpoint just disappears. Only way to get it back is to rebuild the thermostat. The setpoint is then set to 5 degrees.
Then trying to change it, the result is the same.
Why is this?
It has worked before.
Best regards,
Why is this?
Best regards,
