I'm currently migrating from Vera to Homeseer, and right now I'm working on getting thermostats up and running.
But I'm getting a weird issue....
Created my first VStat for my livingroom.
Selected two zwave sensors as internal and external sensors.
Selected a mscMQTT device as control.
Everything _looks_ good, and the first thing that happened was that the heating was turned on.
But then.. It's never turned off!
The "Zone Control" device is always On no matter what.
Current Temperature shows 25 degrees, as the stove is lit, so no need for floor heating, setpoint is 21, but still it's On..
If I manually turn off the MQTT device it will turn off, and if I then change the setpoint of the VStat it will turn the MQTT device back on, so it's able to control it.
Any ideas on what I should check?
Attached are a couple of screenshots in case someone spot some obvious things that I have overlooked.....
Status of MQTT device:
VStat, MQTT device shows at the bottom:
