crash after update 3.0.9.1
  • crash after update 3.0.9.1
    after update in 3.0.9.1 the plugin crash with error :
    WARNING: Failed getting InterfaceStatus from SDJ-VStat - the interface was not found in the list of active interfaces, the list may need to be refreshed.
    thanks for help
    thanks for help
    Did you disable the plug-in before updating?
    Quite often with HS3 you will get this type of error when you update when it tries to update a running plug-in..
    Try clicking on disable and then updating again. If that doesn't work try shutting down HS3 and restarting and see if the plug-in starts up. You might have to enable the plug-in after restarting HS3.
    Let me know how you get on.
    Steve
      Did you disable the plug-in before updating? yes
      test 1 :
      disable plugin
      stop hs3
      start HS3
      install plugin
      same error
      test 2 :
      disable plugin
      delete plugin in hs3
      stop hs3
      start HS3
      install plugin
      same error
      log HS3 :
      Initializing plug-in(2): SDJ-VStat Instance::La conversion de la chaîne "0.19" en type 'Double' n'est pas valide.STACK: Server stack trace: Exception rethrown at [0]: à System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) à System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) à HomeSeerAPI.IPlugInAPI.InitIO(String port) à Scheduler.clsHSPI.CheckInterfaces()
        OK, you've tried everything there.
        Please can you post your system details from the Tools>About Homeseer menu.
        Steve
          works after change decimal from "," to "."
            Current Date/Time: 05/02/2019 17:49:17
            Operating System: Microsoft Windows Server 2012 R2 Standard - Domain Controller
            System Uptime: 0 Days 0 Hours 11 Minutes 28 Seconds
            IP Address: 192.168.1.10
            Number of Devices: 318
            Number of Events: 19
            Available Threads: 200
            HSTouch Enabled: True
            Event Threads: 0
            Event Trigger Eval Queue: 0
            Device Exec Queue: 0
            HSTouch Event Queue: 0
            Email Send Queue: 0
            Anti Virus Installed:
            In Virtual Machine: No MFG:
            Enabled Plug-Ins
            2.9.1.0: InControl Server
            1.0.0.0: InControl WinPhone
            1.0.0.0: InControl WinStore
            1.0.0.1: IPX800
            3.0.0.14: NetCAM
            3.0.6.8: SDJ-Health
            3.0.9.1: SDJ-VStat
            3.3.5.17921: SMS-Gateway
            3.2.0.1: SqueezeBox
            3.0.1.252: Z-Wave
            I've edited out the Helpdesk output from your previous posts as that has your license details in it.
            The error is caused by the fix I added for where one or two users had switched their system from European comma to US period decimal place after installing the plug-in. I tested it all by switching locale's on my system back and forth and the change worked, but it is obviously throwing an error on yours, and potentially others.
            I will look into this and post a better fix.
            Sorry for your trouble.
            Steve
              thanks for all ….. I love your plugin :-)
                I’m glad you can still say that🙂
                I will post another update tonight.
                Steve
                  I am posting version 3.0.9.2 to the updater to correct the bug I introduced in 3.0.9.1.
                  It might be a day or two until it appears so in the meantime I've attached the HSPI_SDJ-VStat.exe file for 3.0.9.2. to this post. If you have updated to 3.0.9.1. and the plugin won't run then unzip and copy this exe file over the one in the HS3 root folder and the pi should start ok.
                  Sorry for any inconvenience.
                  Steve
                  Update
                  3.0.9.2. is available in the updater now so I have removed the attachment from this post.
                    update works fine
                    thanks
                      update works fine
                      Thanks for the confirmation.
                      Steve
