VSTAT config gone
  • #16
    Originally posted by BME View Post
    I found these messages during the startup:
    Apr-17 11:49:07 Starting Plug-In Initializing plugin SDJ-VStat ...
    Apr-17 11:49:07 Info Plugin SDJ-VStat has connected. IP:127.0.0.1:50364
    Apr-17 11:48:45 Plug-In Found plug-in: SDJ-VStat, version: 3.0.9.2
    That confirms that the Error message occurred as the plug-in was starting and at the point that the version number is normally logged as an SDJ-VStat message.
    You said that the advanced tab looked fine.
    I don't see anything wrong, but I noticed that originally the Reference-IDs are not within the Assosited devices and in the next image has Reference-IDs for all devices.
    I don't know why this is or if it means anything.
    I think that is just that you probably updated HS3 between those two screenshots. HS3 have been updating reporting on group associations and one aspect of that is that the RefIDs are shown alongside the names on the Advanced Tab.
    Steve
    • #17
      I just added a VSTAT again.
      When I restarted the plug-in (not the whole system) the version number was not logged and the VSTAT was gone again.
      Which confirms your findings.
      I will update the plug-in now and try again...
      If you haven't deleted your original VStat devices the plug-in should find them when you restart it after updating.
      Let me know how it goes.
      Steve
      • #18
        After the update I had no VSTATs.
        I added a new one and restarted the plug-in.
        Now all the VSTAS are back!
        I will look through all the events in the coming days end monitor the heating.
        Thank you very much for your great support!
        • #19
          That's good news.
          Did you get the warning message in the log when you started the plug-in?
          Warning - Failed to log PI version.
          If you don't mind can you try the attached vserion of the plug-in where I use a different .NET call to return the PI version, see if it works on your system. By the way do you know what version of mono are you using and have you changed it in the recent past?
          The attached is just the exe file so you need to disable the plug-in, copy this exe file over the existing in the HS3 root folder and then restart the plugin. See if you get the version number rather than the warning message in the log when you restart the plug-in.
          Steve
          SDJ-VStat EXE Only 3-0-9-4.zip ​​​​​​​
          • #20
            I'll look at this during the weekend.
            I haven't changed the mono version for some time.
