Hi Steve
Thank you so much for providing this plug-in. I am truly impressed and super satisfied. I have been trying to do a "bit" of programming myself to manage my 14 circuit under-floor heating (currently, meaning running for the last 2 years, only with virtual devices, to see if everything works or not). And after hundreds of hours of struggling and swearing, I find your plug-in, which is much, much better.
I have two suggestions, which would make a lot of sense and value - for me at least.
1. create some sort of a parent device which could be used to store global values for at-home-, night- and vacation temperatues as well as weather compensation values. The various VSTAT devices could then either use global or local values depending on whatever is checked on that VSTAT.
Most of my rooms would have the same "needs", however they may follow different schedules (e.g. juniors room, as he is home earlier than we are). Maybe the storage room in the basement could have lower temperatures, but that room could then just use local values set.
2. also the parent device could have two "some-heating-on" and "some-cooling-on" devices, which should be switched on if just one of the underlying VSTAT devices have the heating or cooling on. That would allow to switch on the heating system pump, if necessary and switch off again when all valves are closed. Of course I could create an event to switch on the pump if one (or more) of the 14 under floor heatings is on (but that would be a long and ugly OR-statement in Homeseer).
Thanks again for a super plug-in.
Best regards
Rene
Copenhagen
Best regards
Rene
Copenhagen
