Criteria for external temperature sensor?
    Hi,
    I've got a weather station that is integrated into homeseer through MQTT. I can't select the temperature sensor as an external sensor in Homeseer. What are the criterea this device is not meeting?
    Originally posted by Fredrick View Post
    Hi,
    On the advanced tab under Device Type (String) change it to MQTT_Receive_Temperature. It will then appear in the lists.
    If desired you can change it back to MQTT_Receive once you have assigned it to a VStat, it is only used to filter what shows in the lists. It shouldn't matter but just in case the mcsMQTT plug-in uses that setting for anything.
    Steve
      Quick and solid reply, thanks!
