Error deleting VStats in HS4 (Solved in 3.1.0.6)
    I noticed when testing under HS4 that I was unable to delete VStats. Further investigation showed that the hs.DeleteDevice function was returning 'False' in HS4 for the parent device even though it was actually deleted successfully. In HS3 it returned 'True'. SDJ-VStat was interpreting the 'False' as an error and aborting the delete of the VStat.
    The updated version 3.1.0.6. simply ignores the returned result and proceeds regardless.
    The only possible side effect of the change would be some orphaned devices if HS4 actually had failed to delete them. This hasn't happened in my testing so I think it is unlikely.
    Steve
