Hi Steve,
I may have found a bug
I have found a problem when creating the 13th SLAVE vSTAT
Once created, if I change "Mode" on the slave, then it ignore the "SetPoint" values and just gives:
11 for "High",
5 for "Low"
5 for "Away"
Is there a limitation of 12 slave VSTATs?
Also if I UNCHECK the "Slave" option on a slave that has this issue then it does not revert to a normal VSTAT and the behaviour remains.
Best regards
/Marcus
11 for "High",
5 for "Low"
5 for "Away"
Best regards
/Marcus
