Hello,
I am in the process of finishing my basement project, had it going a couple years ago but had to press pause on the project. So since it's been a couple years, I wanted to see if this plugin would solve what i need or if there is another option.
I will be installing in wall and toe kick cadet electric 220v heaters, with fan. They have line voltage 220v thermostat connection for control. I have looked at Sinope and Stelpro Ki electric thermostats. I see the Sinope plugin, but it sounds like it may not work with the thermostat that would work with my heaters. I don't see any RF thermostats on the Sinope page. I see wifi, zigbee and control 4 type thermostats. It also looks like the Stelpro Ki can't handle heaters with fans in them.
Has the Sinope plugin made any changes allowing me to use the zigbee or wifi versions? Or is there a way to use the Stelpro Ki? Or any other options?
Thanks for the help!
