Backup Errors & Report Device Status
    Hi,
    I have noticed ActiveBackup throwing up a lot of errors on some of my backup jobs - but it still reports that the backup was OK at the end.
    I am a bit concerned that the backups concerned might NOT be OK...
    I'm using version 2.0.0.22
    See below for example:
    02/05/2006 02:30:00 Info Event Trigger "Software Backup"
    02/05/2006 02:30:01 ActiveBackup Info Report to device: s92
    02/05/2006 02:30:01 ActiveBackup Info Compressed backup started from: R:\Software to E:\Software Backups\ActiveBackup 200605020230.zip. Report to device: s92
    02/05/2006 02:30:01 ActiveBackup Info Destination folder created: E:\Software Backups.
    02/05/2006 02:31:49 ActiveBackup Error CheckPoint RDIM: Exception of type 'System.OutOfMemoryException' was thrown.
    02/05/2006 02:31:49 ActiveBackup Error RDIM Stream Lenght:678081814
    02/05/2006 02:31:53 ActiveBackup Error CheckPoint RDIM: Exception of type 'System.OutOfMemoryException' was thrown.
    02/05/2006 02:31:53 ActiveBackup Error RDIM Stream Lenght:175198004
    02/05/2006 02:33:04 ActiveBackup Error CheckPoint RDIM: Exception of type 'System.OutOfMemoryException' was thrown.
    02/05/2006 02:33:04 ActiveBackup Error RDIM Stream Lenght:219971714
    02/05/2006 02:43:49 ActiveBackup Error CheckPoint RDIM: Exception of type 'System.OutOfMemoryException' was thrown.
    02/05/2006 02:43:49 ActiveBackup Error RDIM Stream Lenght:217449881
    02/05/2006 02:43:50 ActiveBackup Error RDIM Stream Lenght:191654365
    02/05/2006 02:44:07 ActiveBackup Error CheckPoint RDIM: Exception of type 'System.OutOfMemoryException' was thrown.
    02/05/2006 02:44:07 ActiveBackup Error RDIM Stream Lenght:159009229
    02/05/2006 03:07:38 ActiveBackup Info Max ZIP file size reached (1 GB), SPANNING to multiple zip files. Closing: E:\Software Backups\ActiveBackup 200605020230\ActiveBackup 200605020230_1.zip. Current zip lenght: 994548005
    02/05/2006 03:24:43 Router Traffic Monitor Info Router Traffic Monitor Auto-Purge has started...
    02/05/2006 03:25:01 Router Traffic Monitor Info Router Traffic Monitor Auto-Purge was successful!
    02/05/2006 03:47:31 ActiveBackup Info Max ZIP file size reached (1 GB), SPANNING to multiple zip files. Closing: E:\Software Backups\ActiveBackup 200605020230\ActiveBackup 200605020230_1.zip. Current zip lenght: 914999947
    02/05/2006 03:50:38 ActiveBackup Error CheckPoint RDIM: Exception of type 'System.OutOfMemoryException' was thrown.
    02/05/2006 03:50:39 ActiveBackup Error RDIM Stream Lenght:235562025
    02/05/2006 03:50:40 ActiveBackup Error CheckPoint RDIM: Exception of type 'System.OutOfMemoryException' was thrown.
    02/05/2006 03:50:40 ActiveBackup Error RDIM Stream Lenght:235055657
    02/05/2006 04:17:19 ActiveBackup Info Start checking 1 file/s
    02/05/2006 04:21:13 ActiveBackup Info End checking. Result: OK!
    02/05/2006 04:21:14 ActiveBackup Info Delteted old backup E:\HomeSeer Backups\ActiveBackup 200604020145
    02/05/2006 04:21:14 ActiveBackup Info End backupset.
    Hello,
    how much large is the source folder? (Right click on it, then click properties)
    Can you open the zipped backup with WinZip without errors?
      Originally posted by themax74
      Hello,
      The source folder is 10.5GB - the backup is split over 10 zip files and yes they do all open individually... not sure how to check their integrity as a "whole" entity though?
        You can enable the DEBUG option.
        Then,please,post the entire log (zipped)!
        Thanks!
          Pertinent extract of log attached... I don't know if it makes any difference but as I was checking through the log I noticed that two backup jobs overlapped... so when the errors occurred two backups were in progress simultaneously....
            May be the overlapping, due to memory leak.
            Try to execute one backup per time, and see wath appens.
            I'm running on a 1.5 GB memory, and i run two overlapping backupsets without problems.
              Yes I've been having issues with "you're running low on virtual memory, windows will automatically adjust blah blah...." - I only have 768MB of Memory. I will try to keep them separate, but sometimes one job takes longer than normal and then overlaps a later one...
              Cheers.
                Right last night I made sure that only one job would run - my Homeseer folder backup... I still got the 'System.OutOfMemoryException' error.
                I'm using HS 2.1.52 and ActiveBackup 2.0.0.22.
                Here's the log:
                <TABLE cellSpacing=2 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:45:00 </TD><TD class=LOGType0 align=left colSpan=3>Info </TD><TD class=LOGEntry0 align=left colSpan=8>Event Trigger "HomeSeer Backup"</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:45:00 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry1 align=left colSpan=8>Initializing thread array</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:45:00 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry0 align=left colSpan=8>Starting: 0</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:45:00 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry1 align=left colSpan=8>Action: ActiveBackup Plugin-F:\Homeseer 2E:\HomeSeer Backups1s90</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:45:01 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry0 align=left colSpan=8>Started Thread: 0</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:45:01 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry1 align=left colSpan=8>Data of thread 0 : ActiveBackup Plugin-F:\Homeseer 2E:\HomeSeer Backups1s90</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:45:01 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry0 align=left colSpan=8>Report to device: s90</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:45:01 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry1 align=left colSpan=8>Compressed backup started from: F:\Homeseer 2 to E:\HomeSeer Backups\ActiveBackup 200605090145.zip. Report to device: s90</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:45:01 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry0 align=left colSpan=8>Destination folder created: E:\HomeSeer Backups. </TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:45:01 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Warning </TD><TD class=LOGEntry1 align=left colSpan=8>Unable to open: F:\Homeseer 2\32 baycliff road.ldb The process cannot access the file 'F:\Homeseer 2\32 baycliff road.ldb' because it is being used by another process.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:45:01 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Warning </TD><TD class=LOGEntry0 align=left colSpan=8>Trying to making bit per bit copy.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:45:01 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry1 align=left colSpan=8>Bit per bit copy executed. Adding the file to backupset.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:45:02 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Warning </TD><TD class=LOGEntry0 align=left colSpan=8>Unable to open: F:\Homeseer 2\32 baycliff road.mdb The process cannot access the file 'F:\Homeseer 2\32 baycliff road.mdb' because it is being used by another process.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:45:02 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Warning </TD><TD class=LOGEntry1 align=left colSpan=8>Trying to making bit per bit copy.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:45:02 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry0 align=left colSpan=8>Bit per bit copy executed. Adding the file to backupset.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:50:04 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Warning </TD><TD class=LOGEntry1 align=left colSpan=8>Unable to open: F:\Homeseer 2\data\RouterTrafficMonitor\RouterTrafficMonitor.ldb The process cannot access the file 'F:\Homeseer 2\data\RouterTrafficMonitor\RouterTrafficMonitor.ldb' because it is being used by another process.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:50:04 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Warning </TD><TD class=LOGEntry0 align=left colSpan=8>Trying to making bit per bit copy.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:50:04 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry1 align=left colSpan=8>Bit per bit copy executed. Adding the file to backupset.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:50:05 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Warning </TD><TD class=LOGEntry0 align=left colSpan=8>Unable to open: F:\Homeseer 2\data\RouterTrafficMonitor\RouterTrafficMonitor.mdb The process cannot access the file 'F:\Homeseer 2\data\RouterTrafficMonitor\RouterTrafficMonitor.mdb' because it is being used by another process.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:50:05 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Warning </TD><TD class=LOGEntry1 align=left colSpan=8>Trying to making bit per bit copy.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:50:07 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry0 align=left colSpan=8>Bit per bit copy executed. Adding the file to backupset.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:50:34 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Warning </TD><TD class=LOGEntry1 align=left colSpan=8>Unable to open: F:\Homeseer 2\data\UltraLog\HomeSeerDB.ldb The process cannot access the file 'F:\Homeseer 2\data\UltraLog\HomeSeerDB.ldb' because it is being used by another process.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:50:34 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Warning </TD><TD class=LOGEntry0 align=left colSpan=8>Trying to making bit per bit copy.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:50:34 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry1 align=left colSpan=8>Bit per bit copy executed. Adding the file to backupset.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:50:34 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Warning </TD><TD class=LOGEntry0 align=left colSpan=8>Unable to open: F:\Homeseer 2\data\UltraLog\HomeSeerDB.mdb The process cannot access the file 'F:\Homeseer 2\data\UltraLog\HomeSeerDB.mdb' because it is being used by another process.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:50:34 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Warning </TD><TD class=LOGEntry1 align=left colSpan=8>Trying to making bit per bit copy.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:54:19 </TD><TD class=LOGType0 align=left colSpan=3>Info </TD><TD class=LOGEntry0 align=left colSpan=8>Device: Bathroom Shower Fan (B3) OFF</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:57:39 </TD><TD class=LOGType1 align=left colSpan=3>Router Traffic Monitor Info </TD><TD class=LOGEntry1 align=left colSpan=8>Router Traffic Monitor Auto-Purge has started...</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:58:09 </TD><TD class=LOGType0 align=left colSpan=3>Router Traffic Monitor Info </TD><TD class=LOGEntry0 align=left colSpan=8>Router Traffic Monitor Auto-Purge was successful!</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:58:16 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry1 align=left colSpan=8>Bit per bit copy executed. Adding the file to backupset.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 01:58:21 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Error </TD><TD class=LOGEntry0 align=left colSpan=8>CheckPoint RDIM: Exception of type 'System.OutOfMemoryException' was thrown.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 01:58:22 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Error </TD><TD class=LOGEntry1 align=left colSpan=8>RDIM Stream Lenght:765063168</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 02:00:00 </TD><TD class=LOGType0 align=left colSpan=3>Info </TD><TD class=LOGEntry0 align=left colSpan=8>Event Trigger "Make sure Emmas Light is off"</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 02:00:00 </TD><TD class=LOGType1 align=left colSpan=3>Info </TD><TD class=LOGEntry1 align=left colSpan=8>Device: Emmas Bedroom Ceiling Light (L5) OFF</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 02:24:18 </TD><TD class=LOGType0 align=left colSpan=3>Router Traffic Monitor Info </TD><TD class=LOGEntry0 align=left colSpan=8>Computer - Print Server (192.168.0.11) --> 1 PING failure</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 02:27:44 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry1 align=left colSpan=8>Start checking 1 file/s</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 02:29:25 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry0 align=left colSpan=8>End checking. Result: OK!</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>09/05/2006 02:29:26 </TD><TD class=LOGType1 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry1 align=left colSpan=8>Delteted old backup E:\HomeSeer Backups\ActiveBackup 200604090145</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>09/05/2006 02:29:26 </TD><TD class=LOGType0 align=left colSpan=3>ActiveBackup Info </TD><TD class=LOGEntry0 align=left colSpan=8>End backupset.</TD></TR></TBODY></TABLE>
                  Hmmm...
                  Let me take a look at the code.
                  I will let you know.
                  Thank you and sorry for the issue!
                    Try this
                    Shutdown HS
                    Unzip the attached file to the HS folder
                    Restart HS.
                    Let me know!
                      Thanks - I've just installed it and will see how it goes for the next couple of nights.
                        Fixed
                        Hi,
                        Thanks - seems to have done the trick - been running for several nights with no errors, even when I had two jobs running together!
                          Shutdown HS
                          Restart HS.
                          Let me know!
                          The Max74.. what was the fix ?
                          Pete
                          HS 2.2.0.11
                            Added some code to "force" the garbage collector to release allocated memory.
                            Reduced "span on multiple zips" size to 200MB, instead of 1GB
