Introducing AK Smart Device plugin for HomeSeer
This is a sticky topic.
    #31
    Here is an example of one of my event for my occupancy device
      #32
      Thank guys for helping. I was going to suggest manual install @MattL0, but then it will be impossible to reproduce the problem. I'm still setting up Ubuntu VM...
        #33
        That’s why I waited ...But wanna test the plugin at the same time haha.
        But , if you send me the v1.0.0.2 I can test the install process
          #34
          Originally posted by MattL0 View Post
          So, is it possible to impose a condition '' fire only when the target device doesn't have the targeted value''?
          It shouldn't. I check internally stored cached value:
           if (this.ValueCached != state && state!=null)    this.Value = (double)state;
          And I update cached value on start-up and if configuration is changed
            #35
            Even if checking cached value doesn't work (don't know why it wouldn't) - you can use "enforced" trigger, if my help doc and youtube video not sufficient - I can provide more details.
              #36
              And there's Feature Requests topic for that
                #37
                I still can't get the bloody installer working on Linux. Problems (installer.txt) were:
                1. File name in capitals - INSTALLER.TXT
                2.Then forward slashes in file names.
                3 Then Windows line endings
                Now I get "Install of package AK Smart Device was successful" - but it only installs the exe file, no bin dependencies.
                Another possibility is that HS creates the folder in Updates3 "AK Smart Device1.0.0.2" - with spaces, so I guess they use "AssemblyTitle" from AssemblyInfo no idea why?
                So now after whole day wasted I really hate HomeSeer!
                  #38
                  Update is "successful" - but no files are installed?
                  Feb-21 7:28:31 AM Updater Install/Update of package AK Smart Device was successful.
                  Feb-21 7:28:30 AM Updater Installing package AK Smart Device
                  Feb-21 7:28:30 AM Updater Using local file: AKSmartDevice_1_0_0_2.zip
                  Feb-21 7:28:30 AM Updater Downloading update: AK Smart Device
                  Feb-21 7:28:30 AM Updater Starting download of updates
                  Feb-21 7:28:24 AM Warning Using updater override file: updater_override.txt for updates!
                    #39
                    1. file should be 'install.txt' lower case.
                    2. To ensure Windows/Linux compatibility also use lower case and no spaces. Use '-' or '_' if you really need a space. Or use camelCase if necessary
                    3. Keep names/paths/casing very consistent
                    HomeSeer has a builtin mechanism to convert the "" to "/" for paths so don't put too much focus on that but more on keeping naming/case consistent.
                    Sometimes the packaging of the plugin and getting that correct is harder than writing the plugin!!
                      #40
                      That's what I don't understand... Ok, lower case install.txt, no spaces, I even removed spaces for AssemblyInfo "AssemblyTitle", Linux line endings...
                      ,[CHECKVERSION],3.0.0.13
                      HSPI_AKSmartDevice.exe,.,0
                      HSPI_AKSmartDevice.exe.config,.,0
                      CommandLine.dll,./bin/AKSmartDevice,0
                      Hspi.dll,./bin/AKSmartDevice,0
                      AKSmartDeviceVer1.pdf,./Docs/AKSmartDevice,0
                      AKSmartDeviceVer1.htm,./html/AKSmartDevice,0
                      AKSmartDeviceVer1_files.zip,[UNZIPOVER],./html/AKSmartDevice
                      youtube.png,./html/AKSmartDevice,0
                      What I get in HS window printout:
                      12:56:12:4417:[Updater]->Downloading update: AKSmartDevice
                      12:56:12:4419:[Updater]->Using local file: AKSmartDevice_1_0_0_2.zip
                      12:56:12:4420:[Updater]->Installing package AKSmartDevice
                      UPDATER Read section: [CHECKVERSION]
                      12:56:12:8830:[Updater]->Install/Update of package AKSmartDevice was successful.
                      It doesn't seem to go past first line? Why???
                        #41
                        Majority of the install.txt's out there have MS style (CRLF) line terminators rather than Linux style (LF). You might try that.
                          #42
                          I notice in my install.txt that the first line is different from yours (also other lines...), maybe worth a try? Don't remember why - too long ago - , but do remember I had a struggle too wrapping my head around it
                          xxxx,[CHECKVERSION],3.0.0.96
                          JowiHue.pdf,.\Docs,0
                          JowiHue.pdf,.\html\jowihue,0
                          JowiHueImports.xml,.\Config,0
                          JowiHue.db,.\Data\JowiHue,16
                          JowiHue_images.zip,[UNZIPOVER],.\html\images\JowiHue
                          Newtonsoft.Json.dll,.\bin\JowiHue,0
                          WebSocket4Net.dll,.\bin\JowiHue,0
                          HSPI_JowiHue.exe,.,0
                          HSPI_JowiHue.exe.config,.,0
                          -- Wim
                            #43
                            I think w.vuyk is correct. This is direct from the SDK (https://homeseer.com/support/homesee.../default.htm):
                            xxxx,[CHECKVERSION],1.6.0.182
                            ignore the version, I just pulled the example directly from the SDK
                              #44
                              Documentation says "Parameter 1: ﴾not used﴿" - so it doesn't matter.
                              Anyways, I fixed the installer. The problem was using forward slashes in install.txt - HS doesn't understand forward slashes even on Linux?
                              And HS should display an error if it's confused, not just "Install was successful"!
                              Thank you everybody! It was bloody rough day (and night).
                                #45
                                The plugin seems to have a high cpu time number
                                what command do you use to get this? I'm not Linux expert.
                                The plugin doesn't normally consume CPU, I designed (and profiled) the plugin with performance in mind. My Device class uses Observer Design Pattern - so each device subscribes to trigger devices notifications. When the trigger device value changes - I don't search in the loop for affected devices. The state change is directly propagated to all subscribed devices.
                                The subscription process happens when plugin starts (and when you update trigger configuration) - but it's done in backgroun using Task.Factory.
                                It's possible if you have many devices that initial update takes CPU because I iterate every device in the system to check which one is used by the plugin. But again it should happen in a thread - which is configurable - please check in log if you get "UpdateConfiguration: scheduled".
                                If you enable log (per device, there's no global setting) - you can see timing info (and subscriptions) in the log i.e. for RefID 20:
                                Feb-22 12:54:26 AK Smart Device [20]: Duration 'ConfigDevice Triggers': 36 ms. (14 ms.)
                                Feb-22 12:54:26 AK Smart Device Duration 'deviceutility': 22 ms.
                                Feb-22 12:54:26 AK Smart Device [20]: Duration 'UpdateConfiguration': 9 ms:
                                Feb-22 12:54:26 AK Smart Device [20]: 20: [Controlled] [AK Smart Device], timer: True, Value: 100, observers: [20]
                                Feb-22 12:54:26 AK Smart Device [20]: 38: [Screen] [AK PCUtils], timer: False, Value: 0, observers: [20]
                                Feb-22 12:54:26 AK Smart Device [20]: 14: [New Device1] [AK Smart Device], timer: False, Value: 53, observers: [20]
                                Feb-22 12:54:26 AK Smart Device [20]: 15: [New Device2] [AK Smart Device], timer: True, Value: 0, observers: [15]
                                Feb-22 12:54:26 AK Smart Device [20]: SubscribeTo: (Ref: 20) Controlled (On (Screen))
                                Feb-22 12:54:26 AK Smart Device [20]: SubscribeTo: (Ref: 38) Screen (Off)
                                Feb-22 12:54:26 AK Smart Device [20]: SubscribeTo: (Ref: 14) New Device1 (Value53)
                                Feb-22 12:54:26 AK Smart Device [20]: Device used by 'Controlled': 14 38 20
                                Feb-22 12:54:26 AK Smart Device [20]: UpdateConfiguration: started
                                Feb-22 12:54:26 AK Smart Device [20]: Duration 'ConfigDevicePost': 29 ms.
                                Feb-22 12:54:26 AK Smart Device [20]: UpdateConfiguration: scheduled
