Introducing AK Smart Device plugin for HomeSeer
This is a sticky topic.
  • #61
    Originally posted by Rotech View Post
    I have a question, when the zone is active and the light in your example turns on there a delay that starts, so what happens when the the zone is re triggered by the motion sensors does the counter get reset and starts all over again?
    It should, but need to verify. If it doesn't - needs fix.
    • #62
      I'm a bit confused here, which device determines the length of time for the lights to go off?
      Hector
      Win.2003 OS, HS3
      MyTrigger,ACRF2,W800,Zwave
      AP800,Honeywell Stat
      • #63
        Click image for larger version  Name:	Fig5 - Copy.PNG Views:	0 Size:	221.2 KB ID:	1354148
        The device itself has "Count Down" timer - on Timer Config tab (if I get your question correctly).
        And if any trigger (Triggers tab) happens during countdown - the timer resets.
        • #64
          I guess I’m missing something. I’m playing with the plugin but can’t seem to be able to get to device’s already in HS4. Do you have to create all devices or can you use your existing devices? If so how?
          • #65
            I haven't tried it with HS4 yet. HS3 plugins are supposed to work with HS4.
            I will test and port later when I have time.
            • #66
              Just let me know and I'll test it for you. Seems to be a good tool.
              • #67
                Thank you. I'm still trying to finish the latest HS3 version of the plugin before starting HS4 port. It's a big task
                • #68
                  Hi Alex,
                  I wonder, will your PI be able track mouvement ? ie. left to right mouvement or the other way?
                  My case would be to have two ''sensors'', one at each side of a door entrance ( 1 motion + 1 door sensor / two motions sensors/ one motion or door with somobody entering a code on the zwave lock / etc etc) . So a vitual device would indicate : no motion, motion from left to right, motion from right to left
                  It would be a lot simpler with a plugin. doing this with event is a pain.. .From logic ( never done it yet) with the event engine, i think it would involve timers and counters and a lot a events .
                  • #69
                    Originally posted by MattL0 View Post
                    Hi Alex,
                    Hi Matt,
                    May be it's already possible with my plugin, just not straight forward. I need to think...
                    I have a lot of ideas for the plugin.
                    But because of HS4 port everything else will come later. You know...
                    [EDIT] Probably Feature Requests is better place for these questions
                    • #70
                      Totally understand for hs4 . Will repost in time . Anyways as a user I also wait before creating new complex automation
                      • #71
                        I'm sitting in front of my laptop now , annoying my wife
