Not work since .36
    Not work since .36
    Now trying 40 still getting WARNING: Failed getting InterfaceStatus from BLBackup - the interface was not found in the list of active interfaces, the list may need to be refreshed.
    It appears that several restarts of the plugin as well as HS,, and some waiting .5 hr. or so.
      Mine has not run in a couple of days. I just updated to .41. We will see what that will do.
      Michael
      HS3Pro & HS4Pro on Win2012R2
      Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
      BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, JowiHue, NetCAM, PHLocation, Pushover 3P, Random, rnbWeather, UltraLighting3, weatherXML, ZigBee, Z-Wave
        You may have to re-create your BLBackup event actions
        Let a backup run first and see before changing the event actions
        Cheers,
        Bob
          Michael
          Mine didn't run after I updated to .40. I checked the events and it's still there.
          My logs indicated that it ran... but didn't.
          Mar-07 1:00:00 AM Event Event Trigger "System Maintenance BLBackups"
          Hopefully it will run now.
          Bob, where can we go to, to view the changes made in each release?
          Robert
          EDIT: Running the event manually with .41 works. I suspect it will run at the next scheduled backup.
            Hi Bob,
            I recreated my events and kicked the main one off to test it. It started and then I got the following in the log file:
            Mar-07 14:52:15 Warning In ZipFile, exception opening C:\Program Files (x86)\HomeSeer HS3\Data\ultralighting3\ultralighting3.db3 : The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Data\ultralighting3\ultralighting3.db3' because it is being used by another process.
            Mar-07 14:52:14 Warning In ZipFile, exception opening C:\Program Files (x86)\HomeSeer HS3\Data\HSBuddy\hsbuddy.db3 : The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Data\HSBuddy\hsbuddy.db3' because it is being used by another process.
            Mar-07 14:52:03 Warning In ZipFile, exception opening C:\Program Files (x86)\HomeSeer HS3\Data\BLBackup\BLBackup.s3db : The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Data\BLBackup\BLBackup.s3db' because it is being used by another process.
            I looked in the HS3 log files going back a month and have never had this warning with the backup.
            I did get the notice the backup was a success. How can this be if it did not backup the files noted above?
            Michael
            BTW - THANK YOU for putting SUCCESS in the subject of the email. It is huge help. Now I can turn off my other events.
            Michael
              Blade,
              After upgrade to .40 the backups stopped. The daily event fired and I got the following message in Log:
              "Event BackUps All HS3 To BobsOfficePC, Action of BLBackup: Start Backup could not be carried out because its configuration is not complete. "
              Your status Device did not indicate an error/incomplete Backup--it just stayed with the previous days "complete" message. Is that how it should have worked? I hope not.
              Today I upgraded to .41, then tried to manually trigger the BU Event. In the log it indicated the BU event was triggered but nothing happened. The status device was unchanged(still indicating the successful BU BEFORE the upgrades).
              Also your BU log reports show nothing since before the .40 Upgrade!
              BobSpen
                You will need to delete the events and recreate them
                Since I did that mine has been running fine
                Cheers,
                Bob
