Updated yesterday and backup failed
    I was going through my plugins yesterday and updated BLbackup to the latest version. Last night I got an email that the backup failed.
    Checked the logs and got the following:
    ** Backup process (One Zip File - FULL) has STARTED at 8/27/2017 8:05:13 AM...
    ERROR: was not accessible!!
    ** Backup process (One Zip File - FULL) has FAILED at 8/27/2017 8:05:13 AM
    Not much to go on. The backup directory is there, it has disk space.
    Also, I noticed that the backup has run consistently every day until 8/22 and then didn't run again until last night. At least according to the logs. I wouldn't have noticed this unless the backup failed.
    This doesn't make a lot of sense - that backups had stopped running about a week ago, and then arbitrarily I decide to update and they start running and fail?
    Perhaps it does make sense and someone can help me solve this? Thanks.
    go into blbackup and copy/paste the whole log that shows the backup path etc.,,
      I found a Detailed log file in the main HS3 directory. Is this the one you are talking about? Thanks.
        no...go to plugins...manage....blbackup...reports
          That is what I posted in the original message. That is the entire backup log:
          I had the same thing last night, and then I had a complete log from 8/22 when it last ran successfully. I am still trying to figure out why it didn't run from 8/23 until yesterday when I updated the plugin but that is another issue.
            thats it?????
            mine looks like...
            Backup Log for 8/26/2017 6:00:01 AM
            ** Backup process (One Zip File - FULL) has STARTED at 8/26/2017 6:00:01 AM...
            Processing backup directory: C:\program files (x86)\Homeseer HS3 ( Frequency: Weekly (Monday); Include Sub Dirs: Yes )
            Computer Name: Blue; Unique Alias: blue
            Comment:
            Number of backups to keep: 15
            Zip File Path: E:\Blue\Blue\Weekly (Monday)\HomeseerHS3_blue_WEEKLY-MONDAY_2017-08-26_06-00-03_FULL.zip
            Zip Archive: E:\Blue\Blue\Weekly (Monday)\HomeseerHS3_blue_WEEKLY-MONDAY_2017-07-31_06-00-03_FULL.zip was DELETED
            3,330 files were processed
            0 files in use
            1 zip archive(s) deleted
            Backup time: 28 mins, 47 secs
            ** Backup process (One Zip File - FULL) has COMPLETED at 8/26/2017 6:28:49 AM
            ** Backup process took 28 mins, 48 secs to complete!
            Total backup directories processed: 1
            Total files processed: 3,330
            Total files backed up: 3,330
            Total files in use: 0
            Total old backup logs deleted: 0
            Total zip archives deleted: 1
              check your backup directory is right in blbackup
                Check disk space
                HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
                BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
                BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
                  Thanks for the help guys. As I stated in the beginning the only thing I did was upgrade to the latest version of BLBackup. Everything was running fine up until then.
                  I didn't change any configuration, the backup driectories have not changed, I have 118GB free on the main drive and 64GB free on the backup drive - more than enough space to accomplish the task.
                  I used my backups to step back to 2.0.46 and everything is working again. I restored only the hspi file and the .config file in the main HS3 directory.
                  So I can confirm that whatever happened was caused by 2.0.47. Happy to run more tests, but also happy just to sit on the older version for now knowing that I am backed up! Peace of mind.
                    This is odd - I have been running the new one for quite some time
                    Turn on debug logging and then run a small backup and capture the issue. Then turn off debug logging and attach the debug log zipped so I can see what is happening
                    Cheers,
                    Bob
                      Don't fret,
                      When I updated to that version I had the same problem and reverted back to the previous version. After a while, say 2 to three weeks I updated again, and cleaned out old backups from the destination folder. it has worked perfectly since, keep an eye on disk space.
                        I reinstalled the new version and this time it failed but I got a detailed log - attached to this message.
                        @gogs - what exactly did you clean out - all of the zip files? The directory structure as well? Thanks.
                          I am not zipping the folders up, simply saving the entire folder tree. I deleted the older of the directories
                            What is the difference between this plugin and SyncBack program?
                            Both can be zipped
