Memory use climbing on newest HS3 Beta
  • Memory use climbing on newest HS3 Beta
    Hey Blade... not sure if you saw this... don't want to cross post.
    the plugin is jumping in memory use after a few days on the HS3 beta... from 5 to 160MB consistently.
    https://forums.homeseer.com/showpost...&postcount=830
    fyi :-)
    Does BLBackup drop after some time?
    Cheers,
    Bob
      Doesn't seem to...this morning still high so I restarted it. My backups are at 2am, so,that could be when it goes up.
        My backups run for over 4 hours and my BLBackup process is sitting at 15MB right now
        The plugin builds the zip as it goes so the memory may account for that. It does free the memory after the zip is created
        Cheers,
        Bob
          not here.... still sitting around 160MB... never seems to go down after completing a backup.
          I turned on logging... don't see anything....yet.
          here's a quick snap of logs (before debugging.) shows both nights backup... takes 50 seconds. in the middle is when I killed the process.
          Jan-26 6:56:37 AM
          BLBackupInfo
          BLBackup Debug Logging Enabled!
          Jan-26 3:00:50 AM
          BLBackup Info
          The backup process (One Zip File - Full) has completed at 1/26/2018 3:00:50 AM
          Jan-26 3:00:00 AM
          BLBackup Info
          The backup process (One Zip File - Full) has started at 1/26/2018 3:00:00 AM...
          Jan-26 3:00:00 AM
          Event
          Event Trigger "Environmental Backup Homeseer"
          Jan-25 6:15:07 AM
          BLBackup start
          BLBackup plugin has been initialized
          Jan-25 6:15:07 AM
          BLBackup start
          Backup Folders have been loaded.
          Jan-25 6:15:07 AM
          BLBackup start
          BLBackup version is: 2.0.47.0
          Jan-25 6:15:07 AM
          BLBackup start
          Initializing BLBackup...
          Jan-25 6:15:07 AM
          Info
          Plugin BLBackup has connected. IP:127.0.0.1:65384
          Jan-25 6:15:07 AM
          Warning
          I/O interface BLBackup is down, executable is not running, restarting ...
          Jan-25 6:14:39 AM
          Info
          Plugin BLBackup with instance: has disconnected
          Jan-25 3:00:49 AM
          BLBackup Info
          The backup process (One Zip File - Full) has completed at 1/25/2018 3:00:49 AM
          Jan-25 3:00:00 AM
          BLBackup Info
          The backup process (One Zip File - Full) has started at 1/25/2018 3:00:00 AM...
          Jan-25 3:00:00 AM
          Event
