monthly backup question
    Hi,
    Do i need to create an event for the monthly backup?
    I enabled it in the options, but he made no backup for january..
    the last was december.. (BLBackup_Log_2017-12-31_19-08-03)
    regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    I use an event like this to do my daily. Of course you can add a date as you know for monthly.
      thank you for your reply.i already know how to make an event but why is the Frequency in the options? i was thinking if i put to monthly it wil update monthly.. but it doesnt
      regards
        regards
        I use a condition to control which day the monthly backup runs.
        cheeryfool
          regards
          Wow, I don't know what I was thinking. I have used this one before for a monthly backup.
            regards
            I understand your question. It is not clear to me that the frequency dropdown has anything to do with backups other than to determine the subdirectory on the backup destination. When you set a destination directory for a backup the computer name becomes a subdirectory of that destination and the frequency becomes a subdirectory of the computer name directory. Backups are only initiated by events. The actual backup frequency is based on the event frequency. If you take daily backups with an event, using a path flagged as "Monthly", the daily backups will be in the "Monthly" subdirectory.
              Thanks Randy
              Now i understand.
              but actually there is an issue.
              i got in maintain backup directory's
              2 things
              C:\Program Files (x86)\HomeSeer HS3
              Computer Name: HS
              Computer Name: Security system Emergency
              When i make an event to trigger on monthly (the first one in the list) it triggers the second also when its finished...
              i have an virtual for the first and for the second.
              when i make an event to trigger monthly it triggers the first here in the list..
              but after its completed it triggers the second aswell but the status on the virtual device keeps saying currently backupping...
              the second event is an emergency event it triggers only when i want to do manual a backup.. so i tested it out..
              also after finishing that one it triggers the first one for backupping after finish...
              also no status change (virtuals still saying backupping)
              regards
