Somebody's been BUSY (Lots of Blade PI Updates)
    I went to sleep last night and everything was up to date. I wake up in the morning and saw the below on the PI Update screen
    Someone's been busy.
    Bob...anything we should know? Same or similar update across all Plug-ins?
    Not complaining by any means....just curious....don't often see a mass update.
    My home is smarter than your honor roll student.
    https://forums.homeseer.com/showthread.php?t=196104
    Originally posted by rprade
      Well.....that explains it.
        Yes I added debug log limit to each plugin
        Make sure you follow the instructions in that post that SF posted. I screwed up with the values in the BLDebug.ini file and it was too late before I noticed it
        The fix for it is on the post
        Cheers,
        Bob
          Hey Blade...I updated my BLLan PI and it wiped out all the configuration and now shows no computers configured for the plugin.... except in the devices they are still all there and still answering to pings it looks like.... ummm nope I take that back...they are hosed...
            That is very odd
            Can you attach your hspi_BLLAN.ini file zipped
            Cheers,
            Bob
              That is very odd
              I got it Bob...I went back to the old one and updated again and now everything is like it is suppose to be.....gremlins in the works I guess
                Bob,
                Updated to 2.0.56 on BLBackup, then opened "options" to enable a debug log. After checking that option and pressing "Save" an error message came up:
                The following validation error has occurred:
                Backup folder does not exist!
                I do a successful backup each day so I do have a Backup Directory. With this error I can't open the debug .ini to correct the entries.
                BobSpen
                  Hi Bob,
                  I have BLShutdown 1.0.3.0 installed, but the new 1.0.4.0 isn't being flagged as available. I believe there is a small bug in the updater line:
                  BLShutdown,blshutdown.exe,,1.0.4.0, ...
                  should be
                  BLShutdown,hspi_blshutdown.exe,,1.0.4.0, ...
                    Originally posted by BobSpen View Post
                    Bob,
                    BobSpen
                    The options page has not changed
                    Do you have a backup directory specified on the options page
                    Show me a screenshot
                    Cheers,
                    Bob
                      Originally posted by zwolfpack View Post
                      Hi Bob,
                      should be
                      That is something I will have to pass on to HST since they control the updater entries
                      I have emailed them about it
                      Cheers,
                      Bob
                        Bob,
                        This is OPTIONS page, RIGHT AFTER I clicked on debug logging.
                          That is very odd
                          I just did a save here and it was fine
                          That message shows if the destination folder does not exist
                          Very odd
                          Cheers,
                          Bob
                            That is very odd
                            Very odd
                            Bob,
                            This is same folder I use for my daily backups so I know it's good!
                              Attach your hspi_BLBackup.ini file zipped
                              Cheers,
                              Bob
