Here it is.
Somebody's been BUSY (Lots of Blade PI Updates)
Nothing looks odd in the INI file
This is very odd
Your backup folder looks ok
backupFolder=\\BobsOfficePC\HomeSeer3-BUScripts-Programs\HS3-BL Backups
What happens if you change your backup folder on the options page to C:\Temp (assuming you have that folder created)
I am having trouble duplicating this here
OK this is confusing...
Try this
Create BLDebug.ini in the config folder and enter this into the ini file and save it:
Code:[Settings] debugLogMaxSizeLinuxMB=500000000 debugLogMaxSizeWindowsMB=10000000000
1. Disable BLBackup
2. Edit the hspi_BLBackup.ini file and change debugLevel=true
3. Save INI file
4. Restart BLBackup
Now load the options page and then click save
Attach the BLBackup-Detailed.log file zipped here
You may need to change debugLevel=false in the INI file since it likely will not save
Originally posted by Blade View PostOK this is confusing...
Try this
1. Disable BLBackup
3. Save INI file
4. Restart BLBackup
Blade I had the same problem several months ago when I moved to a new pc. I tried to change the backup directory on the new system and it kept telling me it could not find it. At the time my solution was to put it back to the original destination and then create the exact same destination on the new PC. hope it helps you figure it out....
Try this
1. Disable BLBackup
3. Save INI file
4. Restart BLBackup
When I opened the Options Page(after following instructions above) the "Debug Logging" was checked(because I set it to "True" in the .ini ?) and pressing "Save", it still generated the same "Backup folder does not exist!" message! Where next?
BobSpen
Did it create a BLBackup-Detailed.log file in the HS3 root folder
Can you try something for me
Try renaming the folder:
to this:
\\BobsOfficePC\HomeSeer3-BUScripts-Programs\HS3-BLBackups
I am wondering the space is causing an issue for some reason
I am at a loss on this one - I for the life of me cannot reproduce it here
If I enter a bunch of the different paths here they work fine. If I enter one that does not exist it is telling me that it does not exist
Does the IP of the server work?
Absolutely,,,,,, it used many times per minute--I have 4 remote Tablet that constantly send request to the server to keep updated. And of course the Backup Directory path is used daily and works fine.
Could there be something wrong with MY update to 2.0.56?
BobSpen
Try out 2.0.58 in the beta section of the updater
I added more logging
Delete the old debug log first and follow the previous steps
1. Disable BLBackup
3. Save INI file
4. Restart BLBackup
Capture a log of the saving the options page
