Confirmation message written to Device String
    Blade, firstly thanks for an extremely useful plug-in that I, and many others, rely on.
    I have a strange, but fairly minor, issue which is that each time the plug-in runs a backup a particular device string of a ZWave child device gets updated with the confirmation message.
    As you see above the particular device is Ref #2199 which is a child device of a ZWave module in my system.
    Now, as I haven't seen anybody else report this I suspect there is some peculiarity in my setup. However, there must be something that writes the confirmation message to a device string and somehow it is pointing at the wrong device in my system. Possibly a corruption in my database?
    Have you any thoughts?
    Steve
    [ATTACH]69359[/ATTACH]
    Steve
      Look at the “Directories” tab of BLBackup configuration. You will probably find that 2199 is set as the “Status Device Code/Ref”. Either remove the number or create a Virtual Device to use.
      Thanks Randy, it was bound to be something I had missed
      The code fields were actually blank in the Directories tab but in Options the device code ref was q1. I don't know if that was the default or something I entered not realising what it was when I originally installed the plugin. Too long ago for my poor memory.
      I've now created a virtual device and set the ref id in directories and it is using that.
      Steve
