Zip File only 1KB
    Zip File only 1KB
    I just noticed ever since I switched to the new laptop the backup Zip file is only 1KB. The only diference between the two is on the old laptop HS3 was in Program Files and the new laptop HS3 is in Program Files (x86).
    Jim
    Jim
    Did you change the directory path in BLBackup config to match the new one?
      In BLBackup the option was C:\Program Files\Homeseer HS3 but the actual folder is C:\Program Files (x86)\HomeseerHS3.
      Jim
        I figured it out. I had to change the directory location in the plug-in.
        Jim
