Hi Blade,
I'm getting database errors during backup since a few weeks. I wasn't aware of it because the backup job never fails, it just "hangs". This morning I noticed these errors.
I am using hs3linux latest version, also latest version of your plugin. I do not have a clue if this related to a system update or something else.
I already removed the plugin, removed the db files in Data/BLBackup, and reinstalled the plugin.
I also excluded some directories to see if it is related to the files I am backing up. No clue.
Thanks in advance for your help.
Zigmund
Zigmund
May-26 12:17:56 BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: UPDATE tblBackupFiles SET txtExists = 1,txtLastFullBackupDate = '2019-05-26 12:17:56.956', txtLastUpdated = '2019-05-26 12:17:56.956' WHERE txtBackupFile = '/usr/local/homeseer/html/images/homeseer/ui/caution-purple.png' May-26 12:17:56 BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: Could not load type of field 'System.Diagnostics.DiagnosticsConfiguration:configSection' (0) due to: Could not load file or assembly 'System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies.
