Backup is not stored in specified location
    I have BLBackup to back up HS3 wvery night.
    Today I checked my backup folder, and the latest backup was many weeks ago.
    After checking the setting, the plugin is to save the backup to here:
    But after checking the plugin logs, the plugin saves the backup here:
    Why is this?
    Why does the plugin store the backup on the desktop instead of where I have set it?
    Blade , you have any suggestions?
      Can you show me what the event looks like?
      Cheers,
      Bob
        Yes, and there I'm guessing the problem is found.
        But why is there two destination options? ​​​​​​
          That is why - The one in the event will override the other
          The reason there are 2 is because if you are using an event to backup ALL directories (like I do) then you can leave this blank or specify a destination folder. If no destination folder is specified in the event then it will use the one for the directory. If there is not one there then it uses the one in the options page
          Cheers,
          Bob
            Ah, I see.
            Thanks for the clarification!
