New issue
    New issue
    This started happening recently:
    BLBackup Error The backup process (One Zip File - Full) has failed at 8/12/2019 10:50:14 AM
    BackupFunctions.Do_Zip_Backup(): ERROR - Caught this exception processing directory: C:\Program Files (x86)\HomeSeer HS3\data - A device which does not exist was specified.
    I assume that the device that does not exist is the attached USB drive, which does exist. I thought it might relate to the update of the plugin. I went back to an old version and issue is the same. I have attached the detailed debug log. Thanks.
    Have you reported this on Blade's website too? He's more likely to see it there.
      Make sure you have done the steps here for debug logging to work properly
      https://forums.homeseer.com/forum/3r...-debug-logging
      Capture a new debug log of the issue and post the entire log zipped
      Cheers,
      Bob
        Okay. Thanks. I will work on this. Elliott
          The problem I had is solved. It seems to have been a hardware, rather than a software, issue, related to USB hard drive and USB port. Sorry for the bother.
