This shows in the log when I run BLBackup from an event. It is in use I'd assume because the plugin is active, but I would assume other files being backup up are too.
Thx!
Thx!
pr-10 1:10:16 PM | Warning | In ZipFile, exception opening C:\Program Files (x86)\HomeSeer HS3\Data\HSBuddy\hsbuddy.db3 : The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Data\HSBuddy\hsbuddy.db3' because it is being used by another process. |
