I just upgraded to HS4. I need to change the directory from HS3 to HS4, I only see two options to select. HS3 directory or None.
Jim
Jim
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
