Team,
I have 3 backup entries configured:
In events, these ALL appear as "C:\Program Files (x86)\HomeSeer HS3"
So which one should I choose?
Suggestion: Show folder plus unique name and/or comment
UPDATE: the problem seems bigger. When you select one of these in the event, it will run the backup entries for ALL 3.
In my case I ended up with 3 different backup files instead of just the one that I selected.
In the device status you see these devices going into "running" state (2)
(BTW, about the status device: do I have to create a blank device and put the device Ref in the appropriate field?
Suggestion: could you hyperlink the configured Ref so you can click it to open the device page in a new tab?)
C:\Program Files (x86)\HomeSeer HS3 - monthly - all folders
C:\Program Files (x86)\HomeSeer HS3 - weekly - all folders except folders under /html and a /backup folder
C:\Program Files (x86)\HomeSeer HS3 - daily - all folders except /html /Logs /bin /Docs /backup
