Many errors in log but BLBackup works...
  • Many errors in log but BLBackup works...
    blbackup is working however my logs are full of this...
    going to google it too.. but just curious if you know why...
    it just goes on and on and on...
    9:01:21.775 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
     9:01:21.774 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
     9:01:21.774 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUpdated,txtExists) VALUES('c:\program files\homeseer hs3\html\images\homeseer\ui\phone\unread.gif','6/5/2013 9:36:26 AM','6/6/2013 9:01:21 PM',1)
     9:01:21.772 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: C:\Program Files\HomeSeer HS3\Data\BLBackup\BLBackup.mdb
     9:01:21.770 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.
     9:01:21.770 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
     9:01:21.669 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
     9:01:21.669 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUpdated,txtExists) VALUES('c:\program files\homeseer hs3\html\images\homeseer\ui\phone\tel8.gif','6/5/2013 9:36:26 AM','6/6/2013 9:01:21 PM',1)
     9:01:21.669 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: C:\Program Files\HomeSeer HS3\Data\BLBackup\BLBackup.mdb
     9:01:21.667 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.
     9:01:21.667 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
     9:01:21.666 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUpdated,txtExists) VALUES('c:\program files\homeseer hs3\html\images\homeseer\ui\phone\tabzover.gif','6/5/2013 9:36:26 AM','6/6/2013 9:01:21 PM',1)
     9:01:21.666 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: C:\Program Files\HomeSeer HS3\Data\BLBackup\BLBackup.mdb
     9:01:21.664 PM         BLBackup Error    DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.
    Microsoft.ACE.OLEDB error was fixed by following this..
    http://social.msdn.microsoft.com/For...b-41d912d50a64
    MaxJordan91 gave 2 links.. he said the first one didnt work for him.. so then try #2.. i went straight for #2
    AccessDatabaseEngine.exe
    now to google the others...
    so new errors are...
    9:11:06.994 PM	  	 BLBackup Error	 DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.
    9:10:34.550 PM	  	 BLBackup Error	 DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUpdated,txtExists) VALUES('c:\program files\homeseer hs3\config\backup\riggsfamily_2.hsd','5/28/2013 6:53:01 PM','6/6/2013 9:10:34 PM',1)
    9:10:34.550 PM	  	 BLBackup Error	 DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: C:\Program Files\HomeSeer HS3\Data\BLBackup\BLBackup.mdb
    9:10:34.449 PM	  	 BLBackup Error	 DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.
    edited again.. having fun trying to figure out my own problem.. hah..
    anyway it seems that BLBackup is erroring because the HS3 DB is currently locked as HS3 is running?
      I have not tried a backup yet in HS3. I will do that this weekend (probably tonight) and see what happens. Even though the database is open it should get backed up.
      I will see what happens when I try it.
      Cheers,
      Bob
        I just setup a backup of the HS3 folder and all subfolders and it worked perfectly. It created a zip with everything in it.
        Cheers,
        Bob
          Same here. My tests have been done on a life HS3, so with open database. No issues anymore here for the backup itself.
          Wim
          -- Wim
            ok interesting.. well my backup works... just throws errors in the logs..
            so even if it worked for ya.. check your logs..
            i just ran mine again.. and got errors in the logs again but backup ran
            it is not just the db file.. each line is a different file..
            like really a ini shouldnt error..
            hs3updater.ini
              Paste the errors from the latest run you did
              Cheers,
              Bob
                hopefully this fits..
                i have x10 logging on so you will see some of them...
                having the log in sqlite is definitely different.. i may have to see if ultralog gets ported... or use sql studio to see if i can connect
                had to attach it..
                i went to put it here and it said i was over see..
                it was too big!!! 702k when 380k allowed
                  OK this is weird. I am not seeing those errors and mine is logging fine to the database
                  Does the BLBackup.mdb file exist in the /Data/BLBackup folder under you HS install?
                  Capture a debug log of this please and open a help desk ticket on my web site and attach the debug log zipped. I will have a look
                  Cheers,
                  Bob
                    sorry busy weekend.. ill try to do so tonight...
                      yes it does.. so does a .bak
                      interesting... 3.0.0.5 fixed it!!!!!
                      12:23:36 PM BLBackup Info The backup process (One Zip File - Full) has completed at 6/10/2013 12:23:36 PM
                      12:23:07 PM BLBackup Info The backup process (One Zip File - Full) has started at 6/10/2013 12:23:07 PM...
                        Glad it is fixed.
                        Cheers,
                        Bob
                          Thanks. That solution fixed it for me, running HS3 on Win 8.1.
                          The first one fixed the flood of singleton errors in the log, the second one fixed the compactdatabase issue.
                          HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
                          Google Search for HomeSeer Forum
